Configure DHCP general parameters for the hosted DHCP Server to change default values or specify information to advertise on all subnets. Configure only the parameters that apply to your deployment.
The following table defines parameters for the ip dhcp-server command.
Variable | Definition |
domain-name WORD<0-255> |
Assigns a domain name to the DHCP Server. |
domain-name-servers {A.B.C.D} [...] |
Specifies the IPv4 address of one or more DNS servers. You can assign a maximum of eight servers. With multiple servers, list each server address on the same command line with a space between each address entry. |
lease-time <60-300000000> |
Assigns the global lease timer in seconds. The host lease expires when the timer expires. The default is 86400. Note: The DHCP renewal process begins when a lease reaches 50% of
the remaining expiration timer. The client unicasts a renewal
request to DHCP Server, which checks its database before
confirming the renewal.
netbios-name-server {A.B.C.D} |
Specifies the IPv4 address of the NetBIOS server. |
netbios-node-type {0x1|0x2|0x4|0x8} |
Specifies the node type of the NetBIOS server. Enter one of the following values according to which value fits your deployment:
The default setting is 0x0 (unconfigured). |
ntp-servers {A.B.C.D} […] |
Specifies the IPv4 address of one or more NTP servers. You can assign a maximum of eight servers. With multiple servers, list each server address on the same command line with a space between each address entry. |
tftp server-ip {A.B.C.D} |
Specifies the IP address of the global TFTP server for DHCP Server. You must assign an IP address to the server before you can assign other TFTP settings such as a server name and boot image file. |
tftp server-name WORD<0-64> |
Specifies the server name of the global TFTP server for DHCP Server. |
tftp boot-file name WORD<0-128> |
Specifies the file name of the global TFTP boot image file for DHCP Server |
